2600K and P8P67 cpu overclock voltage
sixpac
So I have my P8P67 with bios 1253 overclocked to 4.8ghz (speed step on) and the cpu steps up and down like it should no problem. I have the CPU voltage set to 1.35 in the EFI.
Will the voltage for the Cpu always stay around 1.35v when underclocked by speedstep or should it go up and down like when the voltage to the cpu is set to auto.
I did run prime95 on all cores today while at work at it passed 11 hours with no errors @ 4.8ghz.
Hope that makes sense.
thanks
If you've set the voltage to manual and 1.35v, I don't think it'll go up and down. I'm similar to you, 4.8ghz@1.36v, and my voltage stays fixed. For prime, make sure you're using the Win 64bit version 2.64...that's what always catches an overclock for me that's not completely stable. I had to bump my voltage up from 1.35 to 1.36 to get it to run for 2+ hours without a bluescreen crash. LinX and the old version of prime I was running were stable for many hours at 1.35v.
Ok, good info. Thanks.
Any other tweaks in the EFI you think I should make? I did set my ram to manual timings but didn't set anything else.
