If the OS is the problem and no drivers will be released to fix the issue, I'll be moving back to my 280, or stepping up to a 470 if they're not affected by the same issue. My 280 worked flawlessly, as the 460 does outside of games. It runs Furmark, F@H, OCCT etc with no issues but GPU usage stays low in game.
The 460 is clocked to 830 on the core and a corresponding shader clock, no memory OC. It exhibits the same issue at stock. CPU is a Q6600 @3GHz (won't clock higher), again same issue at stock. 4GB of RAM.
Exact same setup with a 280 was perfect.
Posted via [H] Mobile Device
