Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
You will probably find them to be around 65-70 dollars. Any cable modem that you buy will be able to support 256k speeds so don't go looking for a "256k modem". I would recommend and of the Motorola Surfboard modems. If you have not signed up for cable internet service then go over to Bestu Buy or Circuit City and see if they have any deals where you can get the cable modem for free after activation rebates. Here is a Motorola Surfboard from Newegg that you can buy. http://www.newegg.com/app/viewProductDesc.asp?description=25-122-104&depa=0
