250mm Case Fans
You can find fans of any size if you look in the right place. If you want some, I'd suggest checking an electronics place rather than a computer place, like Digikey which has DC fans up to 482mm (which move 300 CFM and cost $171)
damn bro just strap a box fan on that bitch and be done with it
Just kiddin man, but like the other guy said there are already all kinds of fan sizes if you look around.
I could have sworn I saw them *somewhere*, but likely I'm thinking of the 140mm models - in particular the ones by Aerocool.. Sure wish they'd come out (assuming they're not already) - one of my possible choices for my next case is the CM (original) Stacker..And with that big grate on the side, I was thinking of strapping one of those monsters to the side (seems big enough to allow using the fan w/ little -> no modding - [bit OT] can anyone confirm size of the opening?).
