250GB SATA DeathStar.
69cents
I don't know what is going on. I got this drive about a week ago and slaped it in my 2.4 OC'ed to 3.2 machine and reinstalled everything. I let my computer sit around idle, say that I'm playing FFXI and when I come back and move around my HDD spins up makes a loud click and my computer reboots. Does it in windows too. I would let my computer sit there idle with ATitool and Prime95 running when I come back and try to access anything it just spins up CLICK and reboots.
I clocked my system to default and got the same results. The drive is on it's side in my case near two 80mm fans running all the time. I even took the drive out and installed it flat, still the same click of death.:confused:
I'm going to put my 9800pro and HDD on their own power rail. I have a PC power & cooling 350 watt PSU.
the click of death is an endless loop
where the drive recalibrates after a read\write error then repeats
a single click after initializing a powered down HDD is normal
Power Management
