Okay so this is my first ITX build and ive got some real concerns.
Running Prime95 and my load temps are 80+.
Stock HSF, Stock Speeds, 2500k in SG05..
Suggestions?
_____
*UPDATE*: Tried out a Shuriken Rev B and the heat pipes were against the GPU. I put some black tape on the heatpipes and tried it out. It was hotter than my stock intel HSF w\ AS5.
I moved back to my stock HSF and just added AS5 and now my temps idle in the 30's and load was around 70. I can live with that until i figure out something else to do.
Thinking about kicking my 3.5" to the curb and just getting a 2.5" for DATA storage. I have 2 SSD drives that i use currently (1 for OS, and 1 for games).
So just in case anyone was interested, the Shuriken rev B is not a good choice for multiple reasons
1) poor cooling
2) really REALLY tight fit with a Zotac z68 board, and it WILL apply pressure to your GPU in a PCI-E slot.
Suggestions?
_____
1) poor cooling
