Config:
i5 2500K
8gb G.Skill DDR3 1600
Radeon 5770 @ 925 / 1400
ASRock Extreme3 Gen3 Z68
Crucial m4 64gb SSD
Antec 300 case
OCZ SilentXStream 600W PSU
Cooler Master Hyper 212 Evo
BIOS Settings Altered:
Turbo Boost Power Limit: 300 (short) 300 (long) 1 (whatever third option is)
Core Current Limit: 150
LLC: 5 (Stock but notable)
Spread Spectrum: Disabled
PLL Overvolatge: Enabled
My system runs perfectly @ 44 multi / 1.33 (1.216 load) vCore (fixed) / 65C Load (hottest core IBT max) / ran 10 IBT passes / 9hr p95 blend
To get it stable at 45 multi, I have to crank the vCore to 1.41 (1.264 load). Here it maxes out at 78C, which is as far as I felt comfortable pushing it before asking here.
I will probably end up running at 44 multi, but I wanna test it out some more.
What are the max safe temps you would recommend for IBT stress tests? Under normal use, the hottest it gets is about 8-10C less than IBT load temps.
Do you see any errors in my BIOS settings? I may go back later to mess with offset voltage, but I don't see it being necessary for this.
Or, I could ignore IBT altogether and try to find stability through p95. I feel like this stresses the system as much as I can through normal use. I'm sure I could lower the voltage a ton to achieve p95 stability.
i5 2500K
Crucial m4 64gb SSD
Antec 300 case
