Hey guys right now I am running a stock hsf @ 3.8ghz. Runs great under crysis 2 temps hit 75 degrees or so idle <35degrees.
I am thinking about getting an aftermarket cooler, I was thinking the cooler master hyper 212 or corsair h60. These would require me to pull the motherboard out tho, which i don't mind doing but would avoid if possible.
So would either of those 2 fit in my case? If not what are other good coolers out there that would fit?
Is there a cooler that would work with the same pin configuration as the stock hsf?
Thanks in advance!
Thanks in advance!
