2500k / 2600k build advice
fhiste
I'm looking for advice on a i5 2500k / i7 2600k build.
For the most part, I will be multitasking in Windows. I tend to have lots of browser tabs open at once and have sabnzbd, sickbeard, pytivo, airvideo, messenger, and media player running all the time. I do transcode video (streaming airvideo to ipad) and decompress large rars regularly and I run virtual machines on occassion but I'm not sure I NEED the i7. I don't game a lot, but I like to check out the new games when they come out. I get bored with them quickly and I don't spend hours a day gaming. That may change when Diablo 3 comes out.
No budget, I just don't want to waste money. I tend to go for the best bang for the buck, and have never been able to talk myself into spending $500 on a video card.
3) Where do you live?
Oklahoma. Plan to purchase everything from Newegg unless there is a much better deal somewhere else.
CPU, Motherboard, Ram, SSD, GPU.
I plan to re-use my case (Lian Li PC-V1000b), power supply (Corsair HX520W), dvd-rw optical drive, hard drives for bulk storage, and all external peripherals. If I have to upgrade the power supply I will but I'd rather not.
6) Will you be overclocking?
I want to, but if I don't get a good overclock I can be happy with the stock performance.
My primary monitor is a 30" Dell 3007HC, dual link DVI running 2560x1600. I'd like to game at this native resolution. I'm running a second 20" portrait monitor at 1200x1600 right now but I could do without it.
I can build it immediately. I don't know of any good reasons to wait but I can.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
I want Crossfire/SLI support so that I have the option to add another video card if I'm not happy with the performance of a single card. I realize this would probably require that I upgrade my power supply. I want SATA 6Gb/s to take advantage of the SSD and eSATA would be nice.
Yes. Technet Windows 7 Ultimate 64bit.
Here are my thoughts so far:
CPU: i5 2500k or i7 2600k
Motherboard: ASUS P8P67 Pro rev.3.
Memory: I really need advice here. I feel it's cheap enough to go with 16GB (4 x 4GB?) unless it will cause stability problems. I want good stable RAM. I was thinking G.SKILL Ripjaws X based on recommendations. Always ran Corsair in the past.
SSD: I'm thinking about the Intel 510 120GB SSD, but I'm open to suggestions. This will be for my OS and primary apps, not big data files. I like Intel's reputation but everything is backed up nightly to the WHS so I can survive a failure if the warranty is good.
GPU: I'm thinking a Radeon 6950 or 6970 with 2GB. I want to start with one video card and upgrade to a second card if I'm not happy with the performance. 2560 x 1600 is my native resolution. I hate ATI due to bad driver experiences in the past but it sounds like that is what everyone has been recommending. I don't game enough to put up with bad Windows performance just for good gaming performance. It looks like I have room in my case for a card up to 12" long.
CPU cooler: Do I need one or is the stock one good enough for a mild overclock?
Network performance is important to me because most of my data is stored on a Windows Home Server. If another motherboard would have better on-board networking I'd be interested.
Thanks in advance for any advice!
For transcoding video, you may want to wait for the Z68 chipset, which should be coming out any day now.
Yeah, I guess the new 21" iMacs use them and Anandtech is under an NDA (I assume the rest of the reviewers are too.) Should be very soon.
And fortunately for the OP, he can get a top of the line graphics card for under $500 from AMD.
Thanks for the advice on the Z68 chipset. It seems to make much more sense for my needs. I've been reading reviews and it looks like the ASUS P8Z68-V PRO would be a good choice once it's available on Newegg.
Knowing that the motherboard will take care of transcoding, does the i7 2600k make sense? That was really the only reason I was considering it.
The rest of my component choices should still work fine with the z68, correct? I'd still love some input, especially on the RAM and GPU.
Thanks!
I'm not up to date on Z68 stuff since it's so new, but it's my understanding that for memory what works in on P67 will work on Z68. So even G.Skill value level RAM will work okay. I'm not a big fan of RAM heatspreaders anymore -- they're not always applied correctly by the manufacturer, and they can get in the way depending on the motherboard/heatsink.
For the GPU, I would consider the Radeon HD 6970, but if you don't like AMD, go for a GTX 570 or GTX 580. You haven't listed a budget, and if that's what you prefer, go for it. For gaming, AMD is the better bang for the buck in the GPU arena, but that's because nVidia's pricing is high, rather than their performance being mediocre. A GTX 580 is slightly faster than a 6970, but it's also more expensive.
Not sure if I mentioned it before, but the stock Intel cooler is decent for mild overclock. Otherwise consider a Cooler Master Hyper 212 Plus. Pretty cheap (about $30 on Amazon last time I checked) and good performance. I haven't looked at your case though so make sure it fits.
For the SSD, go Crucial C300, C400, or M4. For Intel, go with the 320 or 510. I'd also wait for the Z68 reviews to be completely out because of it's special SSD caching system (I can't remember the name of it.) There could be advantages to certain SSDs based on that feature, but I would imagine the above will work well with it.
OK, so I'm lost when it comes to memory. I was looking at G.Skill just because it was recommended on some build guides. I don't mind paying a little extra for quality, but I don't want to buy something that is overkill. Can anyone recommend something from Newegg and post a link? Currently, I have this memory in my cart:
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-8GBXM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
I'd also like a link for a good graphics card if anyone has any suggestions. I thought a 2GB 6950 would be fine and I was thinking about this card:
XFX HD-695X-CNFC Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Produ...4150530&cm_re=6950_2gb-_-14-150-530-_-Product
My big concern is 2560x1600 performance, and I haven't been able to find reviews that target this. If a 6970 would do much better at 2560x1600 then I'd get one, but if the 2560x1600 performance increase is marginal with the 6970, I might as well get the 6950 and try it, with the backup plan being to get a second card and crossfire. Any thoughts?
Thanks.
Also, any concerns trying to run a single 6950 or 6970 with the i7 on my Corsair HX520W power supply?
A single should be okay. I usually recommend a 600W+ PSU for that kind of card but the HX units are usually a little stronger than the rest of the pack. For a dual setup, minimum 750W, preferably 850W.
That RAM is on the expensive side. You'll be fine with one of these:
$80 - G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333$69 - Mushkin Enhanced Silverline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
Alternatively, look through some of the 2500k/2600k combos that Newegg has right now. You can get similar G.Skill Ripjaws (1600MHz) for essentially $80. (This combo is one example.)
Edit: Graphics card:
I like that card. If you'd like some info about how a 6970 and a 6950 2GB stack up on a 2560x1600 display, check out HardOCP's review. There are definitely performance increases with the 6970 -- you'll be able to turn the AA up higher in most games while still maintaining acceptable frame rates.
Edit: More about the PSU: How old is your PSU? It might be worth upgrading if it's more than a few years or if you're prefer to be on the safer side.
I placed my order tonight, and I went with:
i7-2600K CPU
Asus P8Z68-V Pro
XFX 6970 2GB
G.SKILL Ripjaws X F3-12800CL8D-8GBXM x2
Intel 510 SSD 128GB
I found a combo as suggested by tonytnnt and had a Promo code as well that saved me over $60 on the memory.
I've had the power supply for a couple of years, but I found a post on a message board from someone using the exact same power supply with a 2600k and the 6970 card without any problems so I feel good about it. Finding a bigger power supply that fits in my case is a problem in and of itself.
Thanks for all of the great advice!
