2500+ or 2.4C????
QwertyJuan
Friends gonna buy a new machine and wants to know which way to go... 2500+ or 2.4C....
Also motherboards... we are looking at the Soltek 75FRN2-L motherboard for the 2500+, but for the 2.4C, if we go that route that is, is the MSI 865PE NEO2-PLS a good way to go???
Thanx
if you have the extra money to spend, I'd go with the 2.4C. I have many of both, and my 2.4's all overclock at least 1Ghz (3.2-3.7Ghz but all of them have hit 3.4 stable)
the P4's dont seem to have as many issues, nor are they as picky about hardware as the AMD NF2 boards are. Plus they take the newer memory like PC4200 and faster without as many issues as the AMD's.
if money is an issue, get the AMD and some good low-latency ddr. Here's some great P4 boards:
DFI Infinity I865PE/LanParty I865PE
DFI LanParty I875B
Asus P4-800E
Abit IC7-Max3
probably some others, im not as familiar with P4 boards other than my DFI's as I am with AMD.
AMD boards:
Abit NF7-S
DFI Infinity NF2
Shuttle (cant remember exact model but there's a couple really good ones)
The soltek you mentioned seems to be pretty good for the money
Epox is always pretty good...Drisler can tell you more about them than I can =)
If you need to build a cheap, but good, PC then get the 2500 Barton. 2.4C is mostly good for OCing and general [H]ard stuff.
if you can spend the extra ... go with with Intel ... if not ... AMD ...
