Ok I'm a bit noobish when it comes to OCing. But I've read as much as I needed to learn how to do it. So here's what I'm running at:
Athlon (non M) Barton +2500 OCed: 12 Multiplyer x 200 FSB. @1.85 Vcore (with a Cooler Master Aero +7 heatsink/fan cooler)
You do the math and the Proc should be pumping at 2.4Ghz, right?
Mobo: ASUS A7NX8-E Deluxe
RAM: Kingston DDR333 (PC2700) 512MB.
Now, CPU-Z says the Multiplyer is at 11x but how is that so when in my BIOS shows it at 12? Also the Vcore shows it's running at 1.905. Is their something wrong that I'm doing/not doing? Is the ram limiting me? IS CPU-Z showing accurate results?
Also, can I push my Proc any higher? If I switch the Multiplyer to 13, 13.5, 14, it won't let me boot up. Right after the BIOS, a message is displayed saying something similar to "Please change your processor speed (multiplyer) back to it's original state". Is this due to the fact that it's "locked"? Is it even safe to push the multiplyer that high?
According to the CPU Data base (www.cpudatabase.com) from the Hardforums Links, a guy OCed his Barton +2500 & the same mobo as mine to 2695Mhz (2.7Ghz) @ 11x245 with just a nice heat sink fan.
So... wtf?
-Logiks
So... wtf?
-Logiks
