2500+ Mobile & Tt Aquarius II
[evo]
Looking to grab a mobile 2500+ which runs at 1.45
so my question is whether the aquarius II would be a good cooler for this chip? I know it hasnt had the greatest reviews, but with the lower voltage chip it should be OK no?
Comments, opinions?
Thanks
negitive... first just go to their site.. where they advertise the unit the picture has 65C on it.. wtf?? thats the advertisment showing 65C usually you want to advertise the lowest temp possible... meh not good for overclocking that unit.. just for basic cooling... just a look i had an extra 100 bucks and i got this water cooling but i cant overclock cause the pump sucks the rad is small and the unit is gay
just my 6 cents :D
no way, of coarse itll be a fine cooler for that chip at stock speed. but what a processor like that youll most likely get the need for speed and try to overclock it some.
