2500 mobile overheat
Squirrel
I was just wondering what the max temperature is for the 2500+ mobile, if anyone knew, or what I should try and keep my chip temperature below.
Currently under stres its running about 55*C, idles around 47*C. Though what is causing this is im running the chip @ 2.6Ghz (217Mhzx12) @ 1.9v
Why dont you take off your heatsink/fan and run a intensive application while monitoring the cpu temp and let us know what the max temp is...
ahah 100, ive got no problems then. That is crazy seeing how they are designed to run cool.
Yeah im pretty sure i can squeeze out a 2.7-2.8 from this chip.
Thanks alot
