2500+ barton highest temp recommend?
Watzup I just replaced all my fans with panaflo fans and I currently getting 42C on my CPU idle I havent tested in full load, but what doyou guys think is the highest temp a barton 2500+ should go for 24/7 on idle and with full load
thanks in advance
not more than 60. I think they can go higher, but I wouldn't risk it
chapin_Fourlife said:
So would 52C temp would be ok for 24/7?
yeah. mine roughly idles at that. damn texas summers. you'll be fine. just so long as it doesn't sky rocket past 65 or even 75.
