That's a shade over $400 (taking into account the fact that stuff is a bit cheaper in the USA)
My friend needs a budget upgrade - mobo/ram/cpu/gfx (and a new PSU is gonna be required to power that I guess)
How do you fit all that into £250 / $400 ?
I was thinking..
That leaves around £100 (about $170) for the cpu/mobo. This where I'm a bit stuck - what do you guys recommend? (oh, he doesn't need onboard sound, already has a good creative card)
The computer will be for all round use - bit of gaming, bit of DVD encoding, you know.. no one particular intensive application. I think the idea is for it to be able to do everything for the next 2 years or so (althought obviously games are gonna have to run on min settings, but that's exptected.. my mate plays COD2 min settings on his 9200 and it runs smooth as ice and looks great).
So I was thinking.. Sempron 3000+ CPU maybe + one of those shitty brand mobos (foxcom, PC Chips, etc)? What do you reckon, I've never bought a cheap mobo before, how much of a difference does it make? Does the the poorer quality chipsets and such really impact on performance?
Also I thought my first 3 choices (ram/gfx/psu) were no brainers.. but if you have better suggestions please do tell me.
Thanks guys
PS oh yeah, one other thing. Are there any geuinely reputable budget PSU brands? I picked this random £20 one... it looks pretty cheeasy though - flashing LEDs, 550w (ahahaha, yeah, sure), although the customer feedback was decent. So generally.. can you get a decent budget PSU (ie one that will have just enough juice to power a moderate system like the one above) for around the £20 (about $35) mark?
I was thinking..
- £58 / 1GB Crucial (everyone tells me the budget stuff causes system instability, crashes, generaly screws your system and you can never fix or trace the prob
- £70 / 6600 of some sort
- £20 / cheapo PSU (well he is on a tight budget)
Thanks guys
