25 liter plexi case for 12x GPU PC
baskobar
PC was build 2-3 months ago but without case
look like this:
https://abload.de/img/tn_30232705_1021442289zpas.jpg
I want to build small mining case, which looks good, take less space, its silent and also will work as little heater at winter.
List of thing which was done:
- custom design of case for 12x gpu without i/o brackets - 35m spacers betwen them
- plexi was laser cut and aluminium cut and drill on manual lathe
- I have to buy 24 risers in total bcoz narrow008c are sold with thick usb cable which was not good for cable managment also have bigger bend radius, so i bought 008c and also 006 regular ones with thin usb cable so i can mix them and use 008c with thin cables
- custom lenght 8PIN from PSU to 4x 6pin riser cables for power
- custom lenght 6pin from PSU to 4pin EPS
- stock fans and i/o metal bracket from gpus was removed (8-9screws each) 100screws total (stock heatsink not intact
- custom laser cut mount for ssd
- ssd is powered from internal SSD pins with custom cable - internal 4pin(2pin use) to sata plug
- fan voltage regulator - LM2596 voltage regulator + 1 @ 5fan 4 pin splitter
TO DO LIST
- side panels
- shorter 24pin cable
Specs:
case: 3mm plexi + 10x10alu profiles - 234x228x476mm - 25,5 liter
fans: delta 92mm 0,6A each @ 8,5-9V
fan controller - LM2596
motherboard - chinese B250C BTC
cpu - pentium G4400
ram - 8gb corsair
ssd - intel 120gb
gpu - kfa2 gtx1050ti
risers - 008c narrow
psu - seasonic(LDLC) platnium 750W
power consumption from wall - 660W
speed - 188mhash @ 660W
That thing looks sweet as hell. What GPUs are they?
Edit
Nevermind. 1050Ti
next one in progress - almost the same dimensions (only change is +1,5cm to width) but will fit 12x rx570 pulse ITX O______O
more you can check on facebook page under VMCszczur
people still GPU mine?
This setup looks nice!
Sure. Still almost doubling my electric bill. Not quite the ~x5 figure it was earlier this year, but yeah.
Most folks don't count in for the times that some of the algos go crazy, like Lyra2REv2 yesterday. I was almost ~.02 /d for a good several hours. Crypotonite v7/Heavy will pop off like that at times too.
While your typical 'high water' profitability mark isn't usually that long a duration (someone's buy bot going crazy?), it can be counted upon enough that your typical haul is higher than what any calculator will tell you.
Yeah when this happens i figure they are testing for 51% attack or some other crazy shit. why else would the bids go up so high. makes me suspicious anyways
custom 2 wire cable for pci-e + riser power
its 1mm electrical cable (rx570 consume less than 4A from riser, and less than 6A from pci-e 6pin socket)
is it safe? why not - for comparasion AWG18 which is 0,82mm is rated 10A max, here i have 1mm and its use half of current)
working for 12hours already (wire isnt even warm)
