2490WUXI problem/question
abnorm
Yesterday I made a mistake of calibrating my 2490wuxi with 12728 hours on it with the original X-Rite Eye-one display 2. (probably 4-5 years old)
I know now after reading the forum that these things don't last more than a few years.
My display is completely off now (bluish/green tint) and I am not sure how to fix it before buying a replacement calibrator. I tried resetting on-screen menu to default, but it made image way too dim at 100% brightness.
Which replacement sensor should I buy now? Any ideas on how to at least make monitor settings tolerable until I get one?
Maybe someone can share their own calibration file I can use for now.
If you set it to native color and 2.2 gamma, it's not at least semi-accurate/tolerable? Do you have colorcomp cranked up? If so, that can lower luminance some.
