Anyone know where I can get 240mm case fans? I just got an In-Win Dragon Slayer case and the side panel has mounting holes for four 120mm fans or one 240mm fan. I'd rather have the single 240mm fan.
Are you sure that case fits a '240mm' fan or are you assuming? The gapes between the fan mounts on the side of the case look 5mm at least so I'd assume it fits a 250mm fan at the side.
