2407wfp revision a04 -> ps3 question
wasteomind
Just have a simple question.
I've been debating picking up a ps3 lately, and if I do I want to use it on my Dell 2407wfp. It is NOT the HC model, there is no HDMI port on this monitor. Its the 2407WFP.
My monitor is a revision a04.
I know I will need a HDMI/DVI adapter or switchbox to get the 1080p thats not a problem.
The question I have is will I run into HDCP problems with this setup? Some people say revision a04 added support for HDCP @ 1080p over DVI, while others say it didn't.
I've been searching forums and googling for ages, and can't seem to find a clear answer. Most threads on the subject are 9+ months old and everyone seems to contradict each other.
Does anyone have experience with this and can help me out?
Thanks in advance.
i think u should be fine... i was researching this when i was going to buy one.
hdcp support was fixed in a03 and up. so if your monitor is a04 you should be fine
i would recommend dvi to hdmi
I loved my a04 when I had it. Best monitor I've owned. Worked great with 360 scaling 1:1
Yeah I have the 360 on my VGA input and love it.
With the new PS3 coming out (MGS4 Bundle) I was debating picking one up finally and just wanted to make sure I wasn't going to run into any lame problems.
Most people seem to think the A04 is fine.
So now I need to decide between the PS3 or the GTX280 (once there are reviews to see it its worth it)
