Oct 11, 2006 #1 N Nocturnal Gawd 2FA Joined Jul 20, 2006 Messages 834 Can anyone confirm whether or not the 2407 has viewing angle problems like the 2405? The 2405 if you look at an all black background, the colors are all washed out. Is it the same for the 2407?
Oct 11, 2006 #2 S Snowdog [H]F Junkie Joined Apr 22, 2006 Messages 11,257 2405 was really bad. I had one. Apparently the 2407 is better. Not as good as S-IPS, but better than typical PVA.
Oct 11, 2006 #3 N Nocturnal Gawd 2FA Joined Jul 20, 2006 Messages 834 Is it comparable to the 2001FP?
Oct 11, 2006 #4 S Snowdog [H]F Junkie Joined Apr 22, 2006 Messages 11,257 Depends which 2001fp. Most are IPS. If it is IPS it will be better than the 2407. If it is PVA then the 2407 will be better. regular PVA < 2407 PVA < IPS
