Hi Everyone,
First time poster, long time viewer
So at my job, I currently have a 2405FPW that I absolutely love. Its an A05 btw, so I believe last revision for that model, in which then it jumps into the A00 for 2407WFP
I know there are some threads on here discussing the revision updates the 2407 has gone through. One of my co-workers has the 2407WFP A03 and another one has the 2407WFP A00 (date August 2007), so I am thinking his is the -HC
Anyways, what I am getting at is with all these revisions, etc... and the fact that according to Wikipedia, the following Panels are used:
2405FPW - Samsung PVA LTM240M1-L01
2407WFP - Samsung S-PVA LTM240M2-L02, AUO M240UW01 (8-bit)
2007WFP-HC - Samsung S-PVA LTM240CS01-001(true 8-bit)
Would I be better of in terms of pure quality for graphics/design work with the older 2405FPW, or one of the 2407 models.
If the 2407WFP (no HC) IS recommended, which revision Model should I go after since I have heard when a revision happens, Dell quietly makes panel changes, etc...
Any information you can provide is greatly appreciated.
Thanks,
Bryan
Thanks,
Bryan
