2405FPW: Those using both DVI and D-Sub inputs, advice please
francis_a
Hi!
Been reading around but really can't find an answer (maybe I haven't looked good enough).
I have been contemplating on purchasing the 2405fpw to run off of my 9800Pro, just waiting on nice coupons to bring down price below $965 right now. From what I read, the 9800Pro should be ok with the 2405 up to a certain resolution. For the 9800Pro, I will use the DVI input.
I have another PC, my work PC which only has a VGA out and uses Intel's 82845G graphics adapter and maxxes out at 1600x1200 but I doubt I can use that resolution so I may use something like 1280x1024
My question is: Will the 2405 able to handle switching between the 2 inputs (DVI and D-sub) having different resolutions? Do the 2 inputs have independent settins so if I want to scale the signal from D-Sub to be 1:1 it won't affect the DVI input?
Many thanks for the help and sorry for the somewhat noobish question as this is going to be my very first LCD and with dual inputs at that.
I ran my computer at 1680x1050 (2005fpw) and my PS2 at a much lower res, then just switched between inputs. That was svideo, but I'm sure vga would be fine too.
