is it just me, or does anybody else see an ever-so-slightly darker spot in the centre of their 2405fpw
this is the replacement I'm onto now, and it shows similar (albeit less) symptoms to my original order
if you set the screen to all-black, turn the lights out and look at the screen from an oblique angle, can you see an ever-so-slightly darker spot near the centre? or is it just these 2 monitors I've had from dell???
