But if you go to the LCD's menu, press Image Settings and then Scaling, and you select Fill, doesn't that work for you either?Mysticcal said:Yes, but I get black bars on the top and bottom...
davidlem said:or just deal with the bars as you're better off watching the movie in its produced aspect ratio than munging things up by stretching it...
