Does the 2405 fpw have a dual link dvi connection?
I found a website that explains the difference between dual link and single link dvi here:
http://www.datapro.net/dvi.html
Also found the formula here to calculate pixels per second(tmds bandwidth):
http://www.evga.com/articles/public.asp?AID=153
Found another site with some maximum displays settings for single and dual link here:
http://psychcentral.com/wiki/DVI
It seems with a dual link dvi capable card and if the monitor has a dual link capable input you should be able to push some higher refresh rates on the native 1900X1200.according to the above. The question is what cards are capable of dual link dvi? Lots of cards say dual dvi but that just means 2 monitors I believe.
