2405fpw base measurements needed please
Sparrow_69
Would someone be kind enough to give me the measurements of the base of the 2405. I checked the user's manual online, but it only states that the lcd is 9" deep, which I'm assuming is the depth of the base. Could someone tell me how wide it is?(base) Thanks
Approximately 10-12" wide (base only, this is just an educated guess on my part)). If no one else responds, I'll give you an exact measurement on Thursday evening. I'm out of town right now, and will be home then to measure.
I don't own a 2405FPW (I wish I did, though), but some rough calculations show that the measurements should be about ±20.5" x ±12.5".
If you are refering to ONLY the base it is roughly 12.5" wide and 8.5" deep (with a little padding on those numbers. The screen itself is 22"wide. Good luck
That's exactly right. Remember that the base has the shape of half a circle and that the circular part sticks out about an inch or so from the panel. :)
Excellent, thanks guys, I appreciate it. I have a 2405 on the way (can't friggin' wait) and wanted to know beforehand if it would fit underneath the hutch on my computer desk. Tks again :)
