2405 users...
skittzle
In your opinion, which looks better. 720p or 1080i.
I have been playing my 360 on the monitor and it looks as if 720p looks a little bit more crisp but the colors are washed out. The 1080i has more jaggies but the color is more vibrant.
I'm curious to know what people are using.
btw, I am using the component HD cables that came with the 360 to play.
isnt 720p by definition better?
sorry i have a 2405 but no 360 :(.
Yes, by definition it is better but I am wondering why my colors go out the window when I use 720p :mad:
I am also using the HD component cables on the 2405.
To me, both 720p and 1080i are vibrant and colorful; I notice no discoloration between the two.
Let me clarify...1080i looks sharper, although you're right, the jaggies are bit more noticeable. 720p gives somewhat of a "softer" image I guess, but it's progressive so it flows a bit smoother as well. To be honest I can't realy tell the difference between the two that much anyways.
