videogamer323
- Jan 31, 2003
Ok, check this out its driving nuts spent around 3 hours trying to figure it out last night.
This is the 2405FPW on DVI with everything fine.
And here is D-Sub and its RED!
I have tried all sorts of things to get this thing back to normal. I am wondering if it has something to do with the factory menu (which i turned on to check the version 1.8) Is there a way to turn it back off. But i messed wit all the color settings and even tried gamma and other software/videocard settings, with no luck.
Something i tried in despiration is writing down all the setting in the factory menu then started messing with the gain and whatnot, but also didnt seem to help. 1 thing to also note Auto Color in the factory menu does not work on D-Sub it says Autocolor failed when i initiate it...
Thanks for any help
Computer in Sig connected to DVI
Second rig is the same only with a TNT2 connected to D-Sub (still does the red when connected to D-Sub on rig in sig
Edit: Here are some pictures of the factory menus on DVI Menu and D-Sub Menu
Thanks for any help
