Just bought the 2404, and would like to connect my other PC's that are connected to a kvm switch, using the component input on the monitor so that I can see them in the PIP window. I can't find a way to just plug in the vga cable from the kvm becasue it appears that the monitor won't display vga in the PIP window. So, I think I need either a secial cable or converter, but am not sure.
Has anyone tried this successfully?
