2405 and xp64
CUSL2MAN
My question is anyone using the 2405 with xp. And if so are you using the plug and play driver or were you able to find a driver for use with xp 64. it tried to use the regular winxp driver but it would not work.
Thanks
Robert
Thanks
Robert
Try windowsupdate? (I'm running 32 bit xp, but thats where I got my driver)
I don't believe you need a special driver. Just plug it in, adjust your VGA settings to 1900x1200 and you are all set. If anything they you may need new vga drivers that allow your card to go to 1900x1200. At least that's the way it is on 32bit, which may of course be wrong for 64bit, in which case I really shouldn't have posted anything.
Thanks for those answers. i checked widows update nothing there. the monitor works fine so ill just leave it. maybe they will come out with a driver.
Robert
The driver is usually needed for color profiles. Most modern monitors with DDC2 and DVI-D can let the OS know everything about timing and resolution hence there is no need of a specific driver.
But if you still want the driver, try here
