So, I have a secondary gaming rig which currently has a 6600GT in it. It is an older card, but seems to serve it's purpose well. On this system, all I play is WoW and Counterstrike: Source.
The spec's of this system is 2x Xeon 3.2GHz, 4GB ram (ya, only sees 3 in XP), 2x 15k SCSI cheetahs in raid0, 2007fp (1600x1200).
I recently got an el cheapo 2400XT, but was wondering if anyone knew if it would be better than the existing 6600GT I have for the games I play at the resolution I play.
I know the 2400XT has received some pretty bad reviews, but in my mind, the 6600GT is a few generations old and you would think todays low end stuff would still be better? Even if it were the same performance, I would be happy since it is lower power consumption and less heat.
Any ideas?
Thanks!
Any ideas?
Thanks!
