I'm thinking about getting the fortron bluestorm 500w for my old DFI NFII Infinity board and was wondering how much of a problem this might cause since I know it adds a little resistance. I've actualy got quite a bit of stuff in it and was looking to add some fans.
XP 3200+ barton
DFI NFII Ultra Infinity
2x1gb OCZ EL Platinum pc3200
2 PATA WD HDDs
2 optical drives
HSF
9800pro 8x agp (possible upgrade to nothing higher than a 6800gt or x800xl)
3 fans (want to add two more).
I'm sort of having a hard time deciding which supply to go with, because with this True430 I've already ran out of 4pin molex connectors and wanted to make sure I got one with enough connectors for 2 more fans and enough power.
XP 3200+ barton
2 PATA WD HDDs
2 optical drives
HSF
