24" thinnest bezel for eyefinity
kandor
Hi,
I'm in the market to upgrade my eyefinity setup. I use 3 24's but they are old and definately not thin bezels.
There is a lot of mis-information on actual bezel width online. I've seen the 24" dell with a 1mm bezel (plus 5mm black inner bezel) for a total of 6mm, not bad.
There is a BenQ EW2440L which reports a thin bezel but I haven't found exactly what it is.
Anything better? What's the very best available for eyefinity at the moment in your opinion?
Thanks!
I can't comment on the models as I don't recall seeing anything smaller than what you listed.
How adventurous are you? For the best eyefinity setup, you can DIY it. Most backlit displays should have a small interior bezel if removed from the housing. For whatever reason manufacturers are stuck on faking (black interior) bezel size over actually doing it (cell phone bezels are tiny). You can strip the plastic (either one side, then reattach or just leave off). Or you can do what this guy did, and use a mirror.
http://www.wsgf.org/forums/viewtopic.php?f=68&t=25230
