rhino.software
- May 30, 2008
hi ,
i have looked around for a cheap pva montitor preferably 24" for gaming and such and found several what looks like the same monitor but rebranded by lots of different companies.
(my first choice would of been the samsung sm245bw untill i found out about the screen lottery ripoff and wasnt going to risk it and then found the 22" sm223bw but someone mentioned they were not very good either...)
please note...
needs dvi connection
needs to be VESA Compliant - 100mm x 100mm
needs Kensington Lock Slot
i haven got blue ray nor intend to use blue ray or HD
aint connecting to consoles (purely pc gaming)
will also use for videos and internet browsing. (general use)
my question is ...is there any real difference between these 4 that id notice?
1....OcUK Value L2442WD-VA....£235 ex postage --------------VGA & DVI
http://www.overclockers.co.uk/showproduct.php?prodid=MO-026-OK
(vesa...dvi) - verified
2....Digimate L2442WD...£200 inc postage --------------VGA & DVI
http://www.ebuyer.com/product/145399
(dvi ) - verified
3... Novatech 24" NOV-LCD24A....£215 ex postage --------------VGA & DVI
http://www.novatech.co.uk/novatech/specpage.html?NOV-LCD24A
(dvi) - verified
4... Yuraku YV24WBH1 24" Monitor...£208 inc postage ----------VGA ONLY
http://www.cclonline.com/product-in...ategory_id=1&manufacturer_id=287&tid=yv24wbh1
(vesa and Kensington) - verified
also of mention is these 2 which get good ratings one TN and the other im not sure but it has 178* angle viewing....
BenQ G2400W (TN panel)
(vesa..Kensington..dvi) - verified
Acer 24" TFT LCD monitor AL2416WB Widescreen 5ms Silver/black 1000:1..£242.04 Inc
http://www.microdirect.co.uk/(21762)Acer-24-TFT-LCD-monitor-AL2416WB-Widescreen.aspx
many thanks and await your replies...
please note...
(dvi ) - verified
(dvi) - verified
