I like the idea of having a larger center screen and was considering doing a 23 24 23 configuration. Will this work well and does anyone have a picture of a similar setup for reference?
i play bf3,wow ,dirt and a few other misc games, I do alot of multitasking and programming on the computer and was thinking about just getting a 2 monitor configuration but having the option to eyefinity when I game would be nice
It will work, even if they are not the same res, they'll just run the highest resolution each has in common. like 1200p and 1080p display mix will run 1080p on each display.
I would recommend throwing the extra money into getting a higher end center 23" monitor rather than the 24". Your center monitor is really going to be the workhorse of the total display, and I'm not sure if I would want it larger because your lines between the side monitors won't matchup correctly.
