I'm in the process of putting some of my new parts in my case. I have the ASUS Z68 Pro motherboard and the Corsair AX850 power supply. I got the 24 pin cable plugged into the motherboard. On the other end of the cable their is 2 connectors. Do both of these get plugged into the power supply? Looks like the larger plug goes in the bottom rail and the smaller plug on the top.(PSU fan is on the bottom of case)
Also the 8 pin cable on the motherboard, it looks like the other end of the cable plugs into the power supply beside where the PCI cables get plugged into.
[/IMG]
In the pic the 8 pin is plugged in. If the other 2 get plugged in, the smaller one would go next to the 8 pin and the other one goes below it.
Thanks
Thanks
