24" or 26" NEC?
mikecoscia
Can't make up my mind on getting either the 2490WUXi or 2690WUXi. There is only $100 difference between the two but not sure if the dot pitch increase is going to be bothersome as I am used to 1650x1080 on a 20" monitor. Although I would not mind it larger so its easier on the eyes, but I only sit like 3 feet away.
Also any one have more issues than the other?
Thanks.
2690 has wide color gamut that is bad.
2490 has better QC "statistics'.
bad for who?? Perhaps OP would like to create a Adobe RGB based color management workflow...
For about 99% of the monitor using population. Thats who.
Even if he has a an aRGB workflow (which provides negligible benefit) everything else he wants to do besides edit RAW images will be compromised.
I purchased the 2490 recently and I didn't even think about the 2690 for a second. PCs are still an sRGB environment. All my colors are fantastic now, in every application, in all games and in movies.
Also important, they are CONSISTENT. They don't change as the color management capabilities of the applications change.
Yeah I am not going to do pro work on the thing. I just want a really good all around monitor for gaming, photo editing, internet browsing, etc... Unfournately there are not many choices to choose from if you want a good monitor, esp if you want something with uniform color and viewing angles.
Snowdog I think I saw your posts about this monitor in another thread and posted a similar question. There was little traffic so posted another thread. Thanks for answering.
I saw your post, but it seemed more like you were thinking aloud, rather than asking a question.
Basically it was no contest for me because of standard gamut of this panel is what I wanted. Also as Albovin indicated, there seem to be less panel defects with the 24 inch version as well. Size difference is trivial. I think this is an excellent size/pitch for an all round monitor.
The only reason to go with the 26" is if you want wide gamut, which most people will be better off avoiding.
I like larger pixels on my 2690, but as some posters suggested, you will get bugged by wide-gamut of 2690. You can save yourself some trouble by buying 2490. Most likely I would have bought 2490, had I a had choice, but no 2490 in Europe. (OK, I know this sentence is wrong.)
