24" Monitors with Lowest Input Lag
sleekone
Where can I find a list of the best 24" Monitors with lowest input lag for a serious gamer. (Im aware they're going to be TN monitors)
Also, which is recommended 1920x1200 or 1920x1080 for GAMING
All in all, im looking for monitors (gaming purposes) that can compete against each other with
Good Brightness
Low Input Lag
Nice Image Quality (I know it wont look like an MVA or IPS monitor, but Im not looking to really open up Photoshop or do extreme web design)
I understand you cant have your cake and eat it to, so I know some monitors will score better than others in certain fields, but for all intensive purposes which ones would fit the best category.
All thoughts are encouraged.
Ive heard mixed reviews on the Dell 2408WFP as far as gaming, some good, some bad, whats the new story?
Hmm, maybe I should have been a little specific, looking for a budget around 350ish, anything more, basically is 2408WFP price. Thanks
I don't think the revision A02 of the 2408wfp is a "bad" monitor for gaming, but as for input lag and response time, there are much better choices if gaming is your biggest priority. I posted in another thread, but basically with the A02, I found the input lag to be ~31ms on average, which, while many don't complain, it is still something to consider when other monitors can offer significantly less input lag *and* lower response time. I really think the only kind of game that is affected by this are the most twitch games out there, i.e. fast-paced FPS, and even then, it is manageable, just depends on how much this lag affects you. I've just read so many reviews of people saying "it bothers me" or "I don't notice it", so, while there *is* lag at ~31ms on average, each person is affected by this to different degrees.
With that in mind, I use a 2408wfp for everything except the most competitive online gaming, in which case, I switch back to my 19" CRT if I'm *really* going for it.
