24"+ monitors that display like laptops
TekRok
i recently bought an HP HDX16t laptop which i customized with a screen of 1920x1080p, it was HD quality. when i looked at my Acer 22" desctop screen i didnt want to go back.
now i want something thats similar to the HP screen on the laptop. is this something possible to get or its only the quality in laptops?
before the laptop i honestly didnt think there ws much difference in screens but i was wrong. maybe its because its 1920x1080 and had HD quality, so that might have been the cookie, i am not aware of anyone making any HD type monitors
Luckily 22" Acer is arguably the worst monitor to buy these days.
There is no HD type or HD quality lcds. HD usually refers to 1920x1080 resolution. 1920x1080 in a 16"? display is a lot of pixels and you won't find that in desktop screens.
yep its 1920x1080 res in a 16" widescreen, it was an option, stock is 13xxby7xx something. what about the Dells i keep reading in this section, whats so special about them? i just want a relly nice monitor with picture better than my acer, although acer was nominated to be the best out of many on newegg it wasnt that bad until i got my laptop that is, its not a bad monitor, but i assume not the greatest
1920x1080 at 16" is a dot pitch of 0.184mm (this is the size of each pixel on the screen).
Almost all 22" monitors are 1680x1050 which gives them a dot pitch of 0.282mm, so it is no wonder you are noticing a difference.
24" monitors are usually 1920x1200 which is a dot pitch of 0.269.
Fact is, you will find very few monitors that go much below 0.270mm dot pitch, mainly because the smaller your dot pitch, the smaller your text, and most humans find it painful to read text that small. This inherent problem won't be fixed until operating systems make changing DPI settings realistic. Windows lets you set a custom DPI, but in practice supports it very poorly (a lot of dialog boxes get all screwed up). Apple is working towards "resolution independence" and is going about doing it the right way, which turns out to be a long hard slog, more so than even Apple expected. I have my doubts that Microsoft will ever get its stuff together to do this.
There are a couple of 22" monitors with 1920x1200 resolution (Lenovo ThinkVision L220X, Eizo S2231W are the ones I know about), which gives a dot pitch of 0.246mm, which is about as good as it gets for desktop monitors, and still nowhere near your laptop screen's dot pitch.
The reason you don't see desktop monitors with tiny dotpitches like laptops is that desktop monitors are expected to be further away from the user's head than laptop displays.
"HD" only means the resolution is 1080p, or 1920x1080. the 'p' stands for progressive, as in 1,080 progressively displayed vertical lines of pixels. HD has nothing to do with anything but the number of vertical lines in a display. It's known in TVs because TVs have always had extremely small resolutions, and now they finally have a more modern display standard. the resolution of a DVD is i think 480p, or 640x480. PC monitors havent been that small in 20 years. finally TVs are catching up to PC displays.
while the HD refers to the 1080p of the 1920x1080 resolution, this infers something else as well. HD is a widescreen format, with an aspect ratio of 16:9 or 16x9. The standardized PC widescreen format is 16:10, and the comparable 1080p PC display is 1920x1200. Basically an "HD" PC display is a nice-sized PC display with 120 pixel lines cut off the bottom (or top, or middle...).
If your laptop were using the standard PC widescreen format of 16:10, you'd have a 17" display instead of 16" and it would be exactly the same width. in a laptop, more or less you're getting less screen in more or less the same laptop dimensions.
are HD PC displays bad? not at all, but im not sure i'd buy a desktop HD display less than a 32" LCDTV. otherwise it has very little benefit to PC users...smaller resolution for the same size display, generally same price, and usually lower picture quality.
also a 30-32" true PC LCD is going to have a 2560x1600 resolution versus the 1920x1080 of a 32" LCDTV, which is almost exactly twice the pixel area.
BTW i have a 32" LCDTV as my main PC display and it's never touched a real TV input.
