24" lcds a gamers nightmare?
tybert7
I wonder about the sanity of this screen size for gamers, I am sure it is fantastic to behold and look at, but the hardware required to run anything smoothly....
And the life of that hardware for the newer games.... With a smaller panel, say a 20" with 1680x10something you have alot more breathing room than the 1900xsomething.
How do you 24" and above gamers cope? You are relegated to the top graphics cards for all eternity? With all the added power requirements, cooling requirements, how can you stand it? Or do I exaggerate the problem?
And what about you crazy folk with 30" monitors for gaming... what are you dealing with?
My current rig (see signature) runs all the games I want to play (M2TW, Insurgency, Project Reality, CNC3) at high settings. If it doesnt I just use the 1:1 pixel mapping at a lower res.
What kind of vid card are you rockin? Unless you haven't upgraded in a few years...or only stick to mainly mid/low-range cards you should be fine running most games on a 24" as long as you don't go too crazy with the eyecandy.
If a game starts to chug a bit I will just drop it down to 1680x1050. My 24" LG does a very good job at scaling.
Bioshock runs pretty smooth at 1920x1200 0xAA on mine. I think Crysis is going to be bring my 8800GTS to its knees at 1920x1200. If that's the case I'll just drop the resolution.
It all depends on a few things
- what games do you play (i play Half Life2 (Cinematic MOD v4), FEAR, GTA: SA, Far Cry, CoD2, Prey, STALKER)
- Graphics card - a 6800/7800 should do fine on most not too extreme new/intensive games (bioshock or medal of honor airborne for example)
- Graphic settings - I try 2x AA @ max settings first, then lowering settings easily, disable AA if chuggy, then i start looking for some tweaks that make the game run better if not there, then lower settings by least important, thats the way i do it atleast, and if lowering the graphics so much, that it doesnt look right/ugly than i start lowering res to 1650x1050 (an just let it stretch).
I have a 7800GS on the AGP platform, but it runs all the games good (for my taste) @ dell 2407wfp (1920x1200), except stalker (had too disable AA and lower some things to about 60% or something)
I run 1920x1200 fine on my 8800GTX, but I tested 1680x1050 and it still looks good. (2407WFP-HC). Scalers are getting better, this is no different than displaying 720p on a 1080p set - we all know that still looks amazing.
