Most monitors have the 4 vesa holes required, the only ones that don't right now are the new LED backlit ones unfortunately.Thanks for posting this. I was about to blow 500 on a dell 2408 (maybe a 2410 with a coupon) because of the height/swivel/tilt functionality.
Now, I just need to find another monitor that has the inputs the dell has.
In slovenia this LCD is nowhere to be found.So far, this is the closest I can find:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824002359
178 degree viewing angles
HDMI
I don't like the pixel pitch, though (.285). I may need to just buckle down and get the dell.
50 € = $74.32It only has 5degress of tilt forward and not recomended for 24" LCDs. I've seen LCDs come equipped with a -5degree tilt. So paying 50€ just for this stand is overkill.
What I meant by expensive was that the HP has TN matrix and poor 160viewing angle but costs 250. Where that ACER costs about 200 and also has 160viewing angle along. Where is the justification for 50 increase in money?the HP is a bit cheaper than the Dell here, but if its not a price improvement for you, then no reason to ignore the Dell as an option (make sense?)
50 = $74.32
$42.68 != $74.32.
http://www.google.com/search?rlz=1C1GGLS_enUS350US350&sourceid=chrome&ie=UTF-8&q=50+€+to+dollarsin a perfect world that would be true.But at least in our country that is far from the truth.
Doesn't change the fact that it's selling for $42.68 from the link I posted. If it's too expensive for you in your country, don't buy it from amazon.
