24" LCD, coming from 19" LCD
ZacharyS
I have a 19" LCD (Rosewill R912E) from a few years ago I've been using. I'm looking to get a 24" LCD soon. I'd imagine most new monitors are superior to this in every way, but I just want a good gaming monitor that has low lag and decent colors like this one. It has served me well.
Basically, I just want a 24" LCD w/ equal or better performance all around. Price, eh, just as low as possible. Dropping some cash is obviously necessary, but I'm not going to spend $800 on just a monitor, I can't do that...
Currently looking at this:
Gateway FHD2400
EDIT:
Also, this will be used for both my PC and for my 360, so it will need at least two inputs (I'm currently using DVI for PC and d-sub adapter for the 360 on my 19" LCD)
You definetely can't go wrong with widescreen the amount of real estate you gain from a 19" will shock you. Even with a 24" most newer pc games now support widescreen and will also be perfect for your xbox360.
I've never owned a gateway monitor but a good friend of mine uses that same monitor and it looks great imo. Problem free and i didn't notice any ghosting or issues while playing games (he plays cs:s,tf2,WoW mainly)
I have a Gateway 24". not that model though. They offer alot of video inputs and is good use for a multimedia LCD panel. The thing about Gateway lcds though is their a chance you will see noticeable backlight bleeding on the panel. My 24" Gateway FPD2485W does have a backlight bleeding on the upper right hand corner. However, Gateway offers vivid colors on their lcds.
