- Jan 28, 2002
Are there any 23 or 24 inch LCDs with IPS or S-IPS panels?
kleox64 said:LG Phillips have been manufacturing the 23" AS-IPS LCD module since november, they dont do 24".
travbomb said:Yes they do make a 24 inch S-IPS panel. Like I said there will not be a monitor with it until this fall. I will take some pictures of it when we get the engineering sample from Japan if you still dont believe me.
Yes, this is the present scenario. Also, it seems that NEC will have few surprises for us, as they will introduce the 24" and 26" panel versions, according to travbomb. Althought, few months ago, I recieved info from NEC that they are not planning the 24" (or larger) GX2 version and that they are preparing the GX3 line for the next year.kleox64 said:LG Phillips have been manufacturing the 23" AS-IPS LCD module since november, they dont do 24".
Thank you very muchtravbomb said:DVL73 apparently you have done your homework.
That was my impression too. In essence, we will not see the up-sized 20WGX2 versions. We will have LCD2690WUXi/LCD2490WUXi ... and they will probably extend the LCD2090UXi legacy with the wide screen form, better overdrive and new CCFL.travbomb said:NEC most likly will not have a 24 inch in the GX2 or 3 line but rather in the MFM line which is new all together.
Perhaps so. But when they hit market, the $2200 Dell 30" will no longer be "the only 2500x1600 LCD " and will nosedive in price.kleox64 said:in any case these monitors will not be cheap, I suggest people start saving and hold off for the next couple of months.
Zak said:Travbomb and DVL73......
thanks for all the info, it is much appreciated by all of us.
Wow, those new "S-IPS" panels coming out this Fall (24", 26", 30" sizes) really sound great.
Which Monitor mfrs or vendors will be selling Monitors that use them?
Model names? Prices? Release dates?
If you're not sure, please make a "best guess".
Big Thanks
A 26" in Sept?travbomb said:NEC 2490 - $1250 - October/November
NEC 2690 - $1400 - September - (92% adobe color gamut)
Zak said:A 26" in Sept?
Sounds intriguing and price is good. Have you seen one? Silver? Black? HDCP compatible? What kind of output connectors? What does "92% Adobe" mean?
Sorry for all the questions but this 26" is first new size in LCD monitors in a long time, and I've been hearing claims that NEC monitors are higher quality than most. Is that true?
