24 Inch - Graphic Design + Gaming
neoian
I currently have a Dell™ E193FP that came with my old desktop in 2004. It is starting to show it's age in more than a few ways. The brightness is stationary no matter what setting it is on and a few spots are burnt in.
I thought it would be nice to upgrade to a 24'' because coding and working in Photoshop is becoming a pain with not much screen real estate available. I am looking for a monitor that provides vivid and accurate colors (with tweaking of course), has a low response time for gaming, and works with an Xbox 360 at 1920x1080 (I think this is called 1 to 1 pixel mapping). I am looking to spend around $350.
If you're going to be doing color critical work, It'll be hard to find something at that price.
Did your current monitor serve you well in terms of color reproduction with the exception of its fading years later? If so, perhaps you could just get a decent TN panel.
If you head out to Staples anytime soon, check out Dell's s2409w if you consider a 1920x1080 TN panel monitor. Some people gave it grief here upon its release without even using it, but I own it and I'm a fan of it. I've read some reviews that compare it to being up there/slightly better than some low end PVA panels that have been compared side by side to it.
Just a thought.
Your price limit limits you to TN panels. TN panels have 6-bit color and dithering, which renders them incapable of displaying accurate color.
A lot of people debate whether TN panels are really that bad at displaying accurate color without understanding what 6-bit color means.
I just picked up a Samsung SyncMaster T240 (24") and I am quite pleased with it for gaming. I'm a FPS gamer myself and had a 22"CRT for years and was afraid to switch to LCD because of response times but I must say this Samsung LCD is great. The image quality is fantastic and response time is great with only minimal blur when moving fast in FPS games.
I don't know if its great for gfx design but for gaming the T240 rocks
