Hi,
I have read many of the posts here about 24" LCD displays. My application is a bit different, so I wanted to ask for some advice.
I need the display for reviewing microscope images that have been pseudo colored. That means the images are composed of a series of 8-bit frames that are each assigned a color (R, G or B) and stacked into a 24 bit image. The goal is to be able to see when the signal in two different channels is in the same place. Since the colors are completely artificial, I don't care if the accuracy is dead on. However, I do care about linearity and signal compression.
What I want:
The main concern is that the display be easy on the eyes for long periods of time, and have lots of detail. In particular, I would like a display that doesn't compress the signal at either the bright or dim end of the scale. Many important details get lost if the monitor lacks broad range, or posterizes at the extreme ends of the scale.
What I don't care about:
Speed or latency. This is not a system for gaming. I don't want bad trailing, but I also don't need it to have 2ms latency.
Absolute color accuracy. Although I would prefer the image not to be way off, the images are in pseudocolor. I am not likely to use this system for production of final figures.
Based on what I have read here, I am considering the following displays:
Samsung 245T
Dell 2408 WFP
I would also consider the NEC 2490, but it is considerably more expensive and I don't need that kind of accuracy. Also, I am buying two monitors, so it gets a bit pricy.
Feedback, anyone?
Thanks,
Dan
What I want:
Samsung 245T
Dell 2408 WFP
Feedback, anyone?
Thanks,
Dan
