so this is going to be cheap >$200 usd
it will be for a backoffice, behind a pizza kitchen so it will be HOT
but it will also need to run 24/7 cause they do their paperwork at home sometimes via remote desktop (or should i just setup wake on lan?)
i was thinking about getting an older optiplex or hp sff or something but i'm worried about their notorious capacitors blowing cause the heat.. so i was thinking either a bigger desktop with a good cooling solution, or move one of the sff's into a midsized atx
what do you guys think?
what are the most reliable sffs? optiplex/hpwise?
i'm trying to scrap parts together from the FS section but buying a prebuilt refurb or used might be even more simple..
another thing i had in mind was changing the HSF on the sff/optiplex
thanks guys
thanks guys
