Hii guys,
Im thinking about getting either the 244t or the 30 inch equivalent. Am I right in thinking that quality wise samsung is the way to go?
Also - my vision is pretty awful. It is very likely I will be running these things at a lower than native resolution. As an example my present 21inch trinitron is running at 1024*768
Is this likely to be a problem? Whilst Ill be watching lots of movies etc I will be doing lots of work/reading on it too.....
(system performance is not an issue as I'll be getting a top spec pc to go with it)
Thanks
Thanks
