24" 1920x1200 sRGB IPS/PLS recommendations
chomba
I'm looking for a 24" 1920x1200 sRGB IPS/PLS display that satisfies the requirements listed below. I've been drowning myself in reviews and forums and just when I feel this display is it some comment sways me to another direction. Rewarding and frustrating at the same time. I would really appreciate any comments you might have about the candidates listed (or similar ones) within the context provided in the usage / technical requirements and preferences.
Usage:
- programming & web development (some graphics work)
-> text needs to be crisp clear unlike on the LP2475w specimen I have*
- web surfing
- office (word & spreadsheet processing)
- entertainment (gaming, movies, tv shows)
Technical requirements (not included -> showstopper):
- 24"
- 1920x1200 (16:10)
- IPS/PLS
- crisp clear text
- sRGB only and it must be accurate within the context of web development & related graphics work
- flicker (PWM) free or as close to it as possible
- input lag no more than on the LP2475w
- DisplayPort & DVI
-> no particular need for anything else (e.g. USB hub, speakers, HDMI/VGA, etc.)
Preferences:
- good/great overall image quality as we all would like to have to the extent possible on IPS
- possibility to adjust text sharpness at any resolution including native (1920x1200) with any connection option (DisplayPort/DVI) is a bonus
- good contrast for IPS but I reckon there are no big/huge differences (CRT/OLED/plasma style)
- IPS glow no more than on a typical LP2475w if that is any indication
- no preference on AG coating (current & previous experiences with coarse / grainy / heavy AG)
-> I had previously a HP 23" Pavilion with heavy AG and text was crisp enough for my eyes so this (faulty?) LP2475w specimen has been a disappointment*
- stock stand that allows the monitor to slide as close to the table as possible
- no need for pivoting (e.g. 90 degress) however slight adjustment functionality is preferred in case monitor is not in OCD-perfect level with the table
-> http://en.wikipedia.org/wiki/Spirit_level this will be used
- no emphasis on stock calibration other than "nice if included"
- warranty period of 2 years is okay if all the above things click but 3 years and beyond preferred
Viewing distance depending on activity (~ 70cm / 27.5in is most common):
60-100cm / 24-39in
Budget is within these candidates:
Asus PB248Q
BenQ BL2411PT
Dell U2412M
Eizo EV2436W
HP Z24i
NEC MultiSync EA244WMi
What would be your choice and why? Any better newer or older candidates?
* Done the run around with the LP2475w specimen I have with regards to blurry/fuzzy text including:
- tested on Windows and Linux (Mint 16, Ubuntu 14.04 beta 2)
- custom scaling enabled for Windows 8.1
- disable ClearType
- enable ClearType and try different combos through the ClearType wizard
- dual screen -> move fuzzy text to second monitor (20" Dell UltraSharp 1600x1200) -> instantly better readibility on both Windows and Linux
I guess I have to drop out some candidates otherwise there will endless back and forth indecision.
If I've read & understood correctly:
Asus PB248Q
- PWM
- reports of abnormally high squealing noise during operation and/or when sleeping / in power save mode
BenQ BL2411PT
- no-PWM
Dell U2412M
- PWM
Eizo EV2436W
- PWM on lower brightness & no-PWM on higher settings
- tolerable input lag
- pricing wise seems that Eizo is pulling a Sony
HP Z24i
- no-PWM
- cross-hatching issues depending on panel type
- blb issues depending on panel type
- different panel types used with the same model -> makes it hard to estimate if you'll have listed issues and to what degree
- found one mention in a forum comment (in German) citing text sharpness as an issue
- PWM
I decided to eliminate the PWM candidates (excluding Eizo). So there would be the three; BenQ, Eizo and HP. Eizo EV2436W has higher price and higher input lag and does not seem to dominate BenQ BL2411PT or HP Z24i in any remarkable way. Possible issues on HP Z24i leaves BenQ BL2411PT which hasn't received any moderate to major complaints.
So far it looks that I will be going with the BenQ BL2411PT.
It seems the better 24" IPS 1920x1200 are:
BenQ BL2411PT
NEC P242W
And the P242W is quite expensive. Not sure what advantages it has that would make it worth the extra cost. It is said to have a semi-gloss AG coating.
The EV2436W is a rip off and uses a grainy matte coating, as does the U2412 and PA248Q.
The BL2411PT (thread with reviews and user reports) is the best along with the Asus PB248Q (not available in North America) which has better external dvd/blu-ray playback abilities according to PRAD's review. The Z24i does have a lighter matte coating than the Asus and BenQ, but it uses both IPS panels (which suffer from coating cross-hatching) and PLS panels (no cross-hatching) and commonly suffers from screen uniformity issues (read this thread).
The P242W costs more because it has a bunch of special features such as the ability to be hardware calibrated. It is really good, but is a waste of money if one does not buy the SpectraView kit to calibrate it over a similarly priced and 27" 2560x1440 monitor (Best 1440p Monitor List).
Where can you purchase BL2411PT in US? It seems like ebay is the only place where I can get it(?).
Thanks for chiming in. I've been to a large IT retail shop and I'm still thinking about my options. I might go with a 2560x1440 instead of the 1920x1200. Looking at one of those (27", Asus PB278Q) I'm a bit concerned about the default size of everything (text, icons, etc.) from viewing distance of 60-80cm (~23.6-31.5in). Messing with Windows DPI settings or increasing text every time when web surfing does not sound appealing. Not all applications will play nice with custom DPI settings.
I saw the HP Z24i on display. Naturally, in a bright lit hall it's hard to see blb / glow. The text on that specimen was sharp though. And there is the option to adjust sharpness for the native resolution (1920x1200) at least for DisplayPort. Build quality was cheapo looking plastic. A friend confirmed the feel. The stand allows the monitor to slide down with an estimate of 4 to 5 cm (~1.5-2in) from the supporting structure.
Did they ever make a 1600x1200 led monitor? None that I can find.
24" is far too large for side-wings
