23 inch gateway problem
cheesehazard
I have a GTW-L23M103 that wont fully power on. The led stays orange. I opened it up to check the voltage on the power supply and it looks like it is working fine although I am not sure because I do not have a pen out for the power supply. Anyone have this problem or know what would be causing it?
did you swap cables, swap VGA to DVI or vice versa, try another computer or video card. if none of that works leave it unpluged for awhile , if all fails sounds like your going shopping.
Yeah I swapped dvi to vga and then to rca, componet and composite and it still does the same. I am trying to order a new one now with a busted screen to swap parts out with my current one. I dont want to drop another 400 on a LCD thats going to go out in 2 years.
