220WM or the 226BW?
TwistedJester
I'm looking to get another LCD to replace the so-so Acer I made the mistake of buying, and I think I've narrowed it down to Samsung's 220WM and 226BW. On one hand, I'd really like to get a 226BW because so many people say that when it's the right panel, it's amazing. Very little backlight bleed (unlike my Acer, which is the main reason I want to sell it) and rich colors. However, that seems to be so only if you get an S panel. I'm worried I might end up with an A or a C.
On the other hand, I don't think there have been any panel lotteries with the 220WM. It doesn't have as good a response time, but I think I could deal with it since it's apparently the same as my Acer, and I can put up with how it looks in motion. It's even cheaper.
So, which should I pick? Are the A and C really that much worse than the S, or can they be brought up to the same quality with the right settings? Which one is more likely to have better blacks and minimal backlight bleed?
